tom_abramov
Data Filter Conditional
With "Conditional" option enabled in Data filter, there are these circles with numbers.
In attached example, :weight is the third column in filter sequence.
The question is: is there some way to change the third column to :height
without reseting entire filter with "Clear" button?
Thanks.
Jeff_Perkinson
Re: Data Filter Conditional
I believe you are correct. There is no way to reset the order of the conditional filters without clearing your selections and starting at (1) again.
Perhaps @chungwei can confirm.
-Jeff
ian_jmp
Level X
Not sure if this is what you are asking, but you can delete variables from their 'little red triangle' then add them back again. Using a script:
NamesDefaultToHere(1);
tab = dt << Tabulate(
	Add Table( Row Table( Grouping Columns( :name ) ) )
ldf = tab << Local Data Filter(
	Conditional,
	Add Filter(
		columns( :age, :sex, :weight),
		Where( :age == 14 ),
		Where( :sex == "M" )
Wait(2);
ldf << delete(:weight);
ldf << addFilter(Columns(:height));
Depending on the details of the use case, you might also be able to exploit the 'Favourites' feature of the local data filter.
tom_abramov
Thanks,
I am looking for simple/without script/without delete solution.
The best solution may be a right click and "Remove from filter sequence" option or something.
I guess, there is no solution for this right now.
Jeff_Perkinson
-Jeff
KarenC
Hover over the weight section title and your pointer will become a hand...click and drag carefully up so it falls between your first and second selections...and drop.
tom_abramov
Thank you.
Unfortunatly, changing column location in data filter doesnt change
its filter sequence in conditional data filter logic
(if I drag weight column, it still has a circle with number three in it)
