DOE experiment design table decimal places
When I create the DOE experiment in JMP, the data table is generated with 8 decimal places. I only need max of like 2 decimal places.
How can I fix this?
Re: DOE experiment design table decimal places
Select the factor columns with 8 decimal places. Select Cols > Standardize Attributes. Click Attributes and select Format. Click Best and select Fixed Dec. You can set the number of decimal places here. Click OK.
Victor_G
Hi @LoglinearMouse1,
Welcome in the Community !
To change the display of numbers with a specific decimal value in the datatable, you can select your columns, right-click and select "Standardize Attributes".
Click on "Attributes", select "Format" and change the setting from "Best" to "Fixed Dec" and enter the value 2 for "Dec" parameter :
Hope this will help you,
Victor GUILLER
