Hi @LoglinearMouse1,
Welcome in the Community !
To change the display of numbers with a specific decimal value in the datatable, you can select your columns, right-click and select "Standardize Attributes".
Click on "Attributes", select "Format" and change the setting from "Best" to "Fixed Dec" and enter the value 2 for "Dec" parameter :
Hope this will help you,
Victor GUILLER
