Hi JMP community,
I am facing a problem with JMP13. I want to create a DOE - Special Purpose - Space Filling Design in order to generate sets of inputs to be used in a another software model. The problem is that I have 2 variables L, H and they have to:
- Be integers (both)
- There sum should be lower or equal than a certain fixed value lets say X
I dont see a way to indicate that these two variables have to be integers in the pop up window. I found an approach to include those variables as "categorical factors" but if you do that then you dont get to constrain them in the "Define factor constrains", they do not appear as options.
Any suggestions how can we solve these kind of issues in JMP?
Thanks
