ComplexNerd
DOE Response and Factor Entry using datatable
Hello guys,
I have recently started to use DOE platform in JMP. is there any way to create response variable from datatable or use copy paste type of any kind. i have 40-50 response variable it feels tedious to type response name forrow wise. can we create this using datatable or any alternative?
Victor_G
Re: DOE Response and Factor Entry using datatable
Hi @ComplexNerd,
In red triangle of any DoE platforms, you can "Load Factors" or "Load Responses" to avoid re-writing them manually : Custom Design Options (jmp.com)
This is also a question from a previous post : Is it possible to load factor or output response setting from a configuration file?
The format of your JMP datatable should be like this :
  • Factors table (one column for each factors, one row for one level):
    Here there are only two levels because the factors are 2-levels continuous factors. Some column properties need to be set :
  • Response(s) table :
Victor GUILLER
Victor_G
Hi @ComplexNerd,
Victor GUILLER
