pcarroll1
Custom markers
Is it possible to create a custom marker, in particular for use in Graph Builder?
We'd like to plot each point as a rectangle with a given aspect ratio.
Re: Custom markers
There are several ways and levels in which you can change the marker for plotting data. Your request is for a marker in the shape of a rectangle with dimensions that depend on variables associated with each observation. In addition to Ian's suggestion, you might consider a script for a custom graphic display. You can start from scratch with Graph Box() or you can add one or more graphics scripts to the frame box in an instance of Graph Builder.
See Help > Books > Scripting Guide and search for 'custom marker.' The 'pixel' oriented drawing functions can render any shape you like.
ian_jmp
Level X
Re: Custom markers
This might help.
Re: Custom markers
