Curve not populating in analysis (4PL Logistic)
I am trying to get a summary graph of my 4 PL curves from the analysis that I did. However, the summary graph containing are not populating with the curves. I've attached some screenshots for reference. Thank you in advance for all of your help!
Re: Curve not populating in analysis (4PL Logistic)
I used an old training example with a reference and unknow curve. I get this after fitting a Logistic 4P model:
What version of JMP are you using? How did you start your analysis? Can you share a picture of the launch dialog you used? Which model did you select from the red triangle menu? What other information appeared in the window after you fit the model?
Byron_JMP
Not sure if this will help?
In an analysis of a very similar data set...
1. The initial plot doesnt' have a curve fit, because it doesn't have a model to make the curve yet
2. After fitting a model:
The fitted curve is displayed in the fit of the model
