BrianK
CuSum chart name
Hi there,
Can someone tell me how to change a CuSum chart name in JSL ?  in the below JSL example
dt = Open( "$SAMPLE_DATA/Quality Control/Oil1 Cusum.jmp" );
obj = dt << Control Chart(
	Sample Size( :hour ),
	H( 2 ),
	Chart Col(
		:weight,
		CUSUM( Two sided( 1 ), Target( 8.1 ), Delta( 1 ), Sigma( 0.05 ), Head Start( 0.05 ) )
	Chart Type( CUSUM ),
The chart name defaults to Oil1 Cusum - Control Chart, as per screen shot below.  I would like to be able to change this in JSL, without having to do a "file, save as" and losing time writing the file to a drive.
I've tried  obj << set name ("test") ; and obj << set control chart name ("test"); to no avail. Any ideas?
Thanks
Re: CuSum chart name
You are trying to change the name of the window, so you can use << Set Window Title
dt = Open("$SAMPLE_DATA/Quality Control/Oil1 Cusum.jmp");
	Sample Size(:hour),
	H(2),
	Chart Col(
		:weight,
		CUSUM(Two sided(1), Target(8.1), Delta(1), Sigma(0.05), Head Start(0.05))
	Chart Type(CUSUM)
obj << Set Window Title("TEST");
	Sample Size(:hour),
	H(2),
	Chart Col(
		:weight,
	Chart Type(CUSUM)
BrianK
worked perfectly, thank you
