Subscribe Bookmark RSS Feed
Creating a .html file
Gabriela_MJ
Occasional Contributor
Jan 4, 2017
I am moving some statistical reports (graphics) from one software to JMP.
At the end of the analysis, I need to put all the graphs (may be .png format) into an .html file.
Is it possible to do this in JMP? I have the scripts for each graph, however I do not find the way to write an .html file yet.
Thanks in advanced.
Jun 22, 2012
Here is the example taken directly from
     Help==>Scripting Index==>Save Interactive HTLM
//This message applies to all display box objects
Open( "$SAMPLE_DATA/Big Class.jmp" );
biv = bivariate( y( :weight ), x( :height ) );
rbiv = biv << report;
rbiv << Save Interactive HTML( "path/to/example.html" );
Gabriela_MJ
Jan 4, 2017
Thanks for your suggestion. However, what I need it to put into a .html file the graphs which are from different (and several) .jmp scripts.
In the software that I used to use, I used to save each graph as an .png file and I writed a routing which creates the .html file using the images. Now, I have the graphs from JMP but I would like to know if it is possible to create the .html report directly from JMP.
Kind regards,
Jun 22, 2012
The answer is yes.  If you want to create your own custom HTLM file, you would use
     Save Text File( path, text|blob, <mode("replace"|"append")> )
Take a look for an example in:
     Help==>Scripting Index==>Save Test File
