  • JMP will suspend normal business operations for our Winter Holiday beginning on Wednesday, December 24, 2025, at 5:00 p.m. ET (2:00 p.m. ET for JMP Accounts Receivable).
    Regular business hours will resume at 9:00 a.m. EST on Friday, January 2, 2026.
saitcopuroglu
Creating a Cumulative Summary Column for different rows
As you will understand from the question I am a newbie to JSL scripting/formulating/automating...I have a revenue data set which contains a column called as "year" of 2013 2014 2015... I need a Cumulative Sum for each year but when I create a column of Cumulative Sum (by the help of Graph Builder) it adds all the days and year one to another and ends up with grand 3 year total Cum Sum, where I would like the Cum Sum start over for each year. I could solve it by splitting or subsetting but since every day I need to send a report of revenue comparison it is really annoying. And this data changes every hour so that would be great to update the existing jmp with the added data and then create the Cum Sum Column for each year... Could someone help please. Thank you!
14 REPLIES 14
saitcopuroglu
Re: Creating a Cumulative Summary Column for different rows
If(Row() == 1 | Lag(:Year) != :Year, :NetRoomRevenueWithOutVat, Lag(:CumSumByYear) + :NetRoomRevenueWithOutVat)
The only thing I can think to check is the value for :Year in the first row with a value of 0.00. If it is missing or different from the previous, then the results would make sense. Otherwise, I'm not able to reproduce it, at least with the data you sent in earlier.
Thanks,
Michael
Michael Crotty
Principal Statistical Writer
Manager, Statistical Documentation
JMP Development
saitcopuroglu
May I send the whole data? I really would appreciate if you manage which saves me a lot of time.
saitcopuroglu
Thank you Michael!
XanGregg
In JMP 11 there is a Transform menu in most platforms that has a Cumulative Sum item. It creates a column with a formula of the form:
If( OrMZ( Row() == 1, :sex != Lag( :sex ) ), 0, Lag() )
+ If( Is Missing( :height ), 0, :height )
It also relies on the grouping variables being sorted, but it ignores missing values.
