tnodd
Creating a Bivariate and Variability Chart Side by Side inside a loop for mutiple parameters and groups
I have an idea what may need to be done but not sure how to implement it. I have a small sample table (say) like this (just showing 4 rows)
dt
         Group    Parameter   Value    Class     PhaseLabel      Date
           A              X               2            pq             z                  xxxxx
           A              Y               6            re              z                  xxxxx
           A              R               2.6         uy             u                  yyyyy
           B             X                4            yt              z                  qqqqq
           B             R                3            er            s                    rrrrrrr
So I want to create jrn-> html for each of my groups ( distinct html files). In each html file there will be plots which will be appended using a V List Box. However, the issue is that I need to have a side by side ( one Bivariate & one Variability Chart)
I am able to produce either a Bivariate or Variab Chart, but cannot do both. I put the skeleton of the code below:
out_path  = "*****"
Summarize( groupid = by(:Group));
Summarize(paramgrp = by(:Parameter));
mydf = {};
For (k=1, k<=N items(groupid),k++,
     grp_name = groupid[k];
      myhtm = New Window( "30d Trend Plots Group Wise", myhtm[k] = V List Box() );
      For( i = 1, i <= N Items( paramgroup ), i++,
               idname = Char( paramgroup[i] );
               outfile = out_path || grp_name || "_" || "trend_plots" || ".html";
               df_ooc = dt_month << Bivariate(
                     Y( :Value),
                     X( :DATE),
                    Where( :Parameter == idname),
                    Where (:Group == groupname),
                    By(:Group :Parameter),
                 mydf[k] << append( Report( myhtm))
          ); ///// 2nd for loop end
             jrn_df = New Window("Trend Correlation Report", << Journal) ;
            mydf[k] << Journal(Freeze All) << show window(0);
             jrn_df << Save HTML(outfile);
             Close All (Journals, "No Save");
);   1st for loop end
Now the above code works perfectly fine when I want to have 1 journal for each group which plots wither a Bivariate( shown here) or if I want a Var Chart ( if I just replace Bivariate with var Chart as a function of Class & Phase Label). However, what I want is inside each group( first for loop for each parameter( inside 2nd loop ) the bivariate and var chart side by side. So that means say if I have 4 groups then I should have 4 journals ( html file) and if for each group say I have 5 parameters then on each html file I will have total 10 plots in 2 columns ( 1st Column say Bivariate and 2nd Column say Var Chart) . I was trying to use H Box inside the 2nd for loop and trying to append the two plots but its not working.
I will really appreciate help. If any other info is needed I can provide it.
Re: Creating a Bivariate and Variability Chart Side by Side inside a loop for mutiple parameters and groups
I have reworked your script a bit.  You will need to go through it an study what I have done.  The basic issue is that when you use a BY() on the platforms, it generates a separate report for each level of by.
The script as written will generate the journals for each group.  I have commented out the show window and the saving of the journal to html.  I did this, so to start with you will see the different journals.  You just need to take the comments out, and it should work the way you want.
out_path = "*****";
Summarize( groupid = by( :Group ) );
Summarize( paramgroup = by( :Parameter ) );
mydf = {};
For( k = 1, k <= N Items( groupid ), k++,
	myhtm = New Window( "30d Trend Plots Group Wise", lb = Lineup Box( N Col( 2 ) ) );
		df_ooc = dt << Bivariate(invisible,
			Y( :Value ),
			X( :DATE ),
			Where( :group == grp_name ),
			By( :Parameter ),
		vc = Variability Chart(invisible,
			Y( :Value ),
			X( :Date ),
			Std Dev Chart( 0 ),
			where( :group==grp_name ),
			By( :parameter )
		// For each value in the By group, there is a separate report
		theEnd=.;
		try(theEnd=nitems(df_ooc)); if(ismissing(theEnd), theEnd=1);
		For( rptGroup = 1, rptGroup <= theEnd, rptGroup++,
			IF( theEnd == 1,
				lb << append( Report( df_ooc ) );
				lb << append( Report( vc ) );
				lb << append( Report( df_ooc[rptGroup] ) );
				lb << append( Report( vc[rptGroup] ) );
		df_ooc << close window;
		vc << close window;
	jrn_df = New Window( "Trend Correlation Report", <<Journal );
	text box("Group = " || grp_name)<<journal;
	lb << Journal( Freeze All );// << show window( 0 );
	myhtm << close window;
	//jrn_df << Save HTML( outfile );
	//Close All( Journals, "No Save" );
);   //1st for loop end
The script worked without error on your supplied sample data.
out_path = "*****";
mydf = {};
			Y( :Value ),
			X( :DATE ),
			By( :Parameter ),
			Y( :Value ),
			X( :Date ),
			Std Dev Chart( 0 ),
			By( :parameter )
		theEnd=.;
			IF( theEnd == 1,
		vc << close window;
tnodd
Let me check out on the real data and I will get back soon. Thanks so much Jim. You always are fabulous!
tnodd
Thanks, Jim. Yes, I tested on my real data. It worked like charm. Learnt a new thing!
