Probe_PE
Creating JMP script for data manipulation
Hi i want to create a JSL for following table
title1Title2Title3stack1stack2stack3..............stack(n-1)stackn
ACE0.55.0100..........2045.65
BDF1.521055.35.........2241
for this table i want to create a script
which will create a new table with stacked all columns from stack1 to stack n. then in new table add new column at the end which will put numbers  1,2..25 abd repeat same sequence till end ofthe table.
Re: Creating JMP script for data manipulation
I suggest using the interactive Tables > Stack command to achieve the first desired result. You can then copy the Source table script to a script window. You can easily add a new column to the stacked data table with the << New Column() message. The Repeat() function used with the Index() function should provide the values easy enough.
Probe_PE
could not see source table script. how to get that ?
The data table that results from the Tables > Stack command should have a table script called Source in the table panel.
Probe_PE
Hi thanks. i got my script. but in that script i have all columns names individually. is there a way that i can make a loop out of it?
