tatarjj
Simultaneously change column width of all selected columns in JMP 14?
Hello all,
Our IT recently pushed JMP 14 onto us.
In JMP 13, with multiple columns selected, if you adjust the width of one column, all selected columns to the right of the one you adjusted change width to match.  This is an extremely useful feature when you have to adjust 30 column widths on multiple files every day!!!
In JMP 14, with multiple columns selected, if you adjust the width of one column, only the width of the column you have selected changes.
The multiple column width adjustment feature from JMP 13 was so vital to me that I uninstalled JMP 14 so that I could revert back to JMP 13. However, IT claims they will delete JMP 13 in a few months from "our" computers.  Also, I'm sure there's things that JMP 14 adds that I would like.  So, is there a way to bring the old behavior of multiple column width adjustment back to JMP 14 so that I can reinstall and use it?  Maybe it was just hidden behind a keypress like CTRL or ALT (I tried, and holding CTRL didn't do it)?
ian_jmp
Level X
Re: Simultaneously change column width of all selected columns in JMP 14?
With JMP 14.3 on a Mac, holding the 'Alt' key does it.
Thanks Ian.  Works the same for Windows.
ian_jmp
Level X
tatarjj
Thank you so much!  That works!
