pmroz
Create Table and then Save it in JSL
Hello JMPers,
I'm creating a dataset by retrieving data from Oracle. Immediately after getting the data I want to save it, using a name chosen by the user. The JSL looks like this:
dt = open database(dsn_string, sql_statement, "MedDRA Categories");
dt << save();
However, I don't get the File > Save dialog. Instead it just tries to save the file (somewhere?) and the log shows the error messages
The file cannot be opened for writing, opening for reading only.
This file could not be saved with the given name.
mpb
mpb
Re: Create Table and then Save it in JSL
I didn't see it in the 8.0.2 docs but fooled around a bit and found that this brings up a save dialog:
dt << save("");
The docs do say that dt << save() saves using the current table name.
I should add that I tried this using an Excel file as my "database" via ODBC. Not sure that the save thing has anything to do with how the table was created although I must say that I did not get the error messages you saw using save() and the file was successfully saved;
Michael
mpb
mpb
dt << save("");
Michael
pmroz
That worked great. I don't think I would have figured that little trick out. Thanks a lot Michael!
pmroz
New wrinkle on this problem:
I'm creating some XML text and would like to save it to an XML file. I'm creating a default output filename, and would like the user to have a little control over the process. I want something like what happens when you use SAVE(""), only I want to provide a default filename, and the extension must be XML.
It looks like the PICK FILE function can do the job:
path = pick file(, , , , , )
Prompts the user with an Open window, returning the pathname of the chosen file. The filterList argument is a list of strings of the form: "Label|suffix1;suffix2;...". The first filter argument specifies which filter is initially shown. The fifth argument indicates whether the window should function as a save (saveFlag = 1) or open (safeFlag = 0) window. The final argument specifies the file that is initially selected.
However the saveflag doesn't appear to work as advertised:
xml_default_file = "myfile.xml";
xml_file_path = pick file("Save the XML file", "", {"XML File|xml", "All Files|*"},
1, 1, xml_file);
save text file(xml_file_path, xml_text);
I get errors saying the file myfile.xml does not exist.
Thanks for your help!
Peter
Jeff_Perkinson
Hi Peter,
I just tried your example and it looks like there might be a bug here.
Please send a note to tech support (support@jmp.com) and let them have a look.
Jeff
-Jeff
mpb
mpb
Looks like the designators for open and save are reversed. Ie, 1 wants to open and 0 wants to save. The following does work but shouldn't if the function is fixed to operate as documented (or maybe the docs should be changed?):
xml_text = "Some text to be saved";
xml_file_path = Pick File(
1,
0,
xml_default_file
Save Text File( xml_file_path, xml_text );
pmroz
Works like a charm. Thanks for poking around on it. I'll notify tech support.
Regards,
Peter
