Column to List
Please excuse the newbie question...
How can I read in column values to a list or, alternatively just add items to a list.
Thankyou
Fanie
carole
Re: Column to List
You can use :
lst = column("ColumnName") << GetAsMatrix();
lst will be a list if your column values are string, or a vector if numeric.
You can tranform a vector into list with AsList() but lots of properties are the same between vectors and lists.
To insert one value by value you have to use :
lst = list();
InsertInto(lst,value);
Hope i answer your question,
Carole
Re: Column to List
Thank you ... it worked great!
