Jain
Create Jmp file from C#
I want to create a jmp file with a simple spreadsheet like below using C#. How can I achieve that? I will appreciate any pointers or sample code.
Name    Salary
John    70000
Mike     80000
Michelle 90000
Thanks,
Shrish
10 REPLIES 10
Craige_Hales
Re: Create Jmp file from C#
Or, if you really want C# to emit a data table, try this:
In JMP, make a table that looks like what you want, including a few rows of data, and with columns of the right type (character, numeric). Use the red triangle to copy the script, and paste into an editor. If you study the script, you'll see how you could write a similar script from C# to a .JSL file, with your data substituted in. Running that .JSL file will make the data table in JMP.
Craige
