Akane
Community Trekker
Create Dashboard and save as Interactive HTML JMP14.1.0
I created dashboard of many graphs and save as interactive HTML, using JMP 14.1.0
Graph in JMP looks ok but graph in Interactive HTML shows 3 decimal and I don't want this. I tried to search how to set for interactive HTML but couldn't it. Please advise.
	Elements(
		Bar( X, Y, Legend( 9 ), Bar Style( "Stacked" ), Label( "Label by Value" ) )
Graph in JMPGraph in JMPGraph in Interactive HTMLGraph in Interactive HTML
Re: Create Dashboard and save as Interactive HTML JMP14.1.0
The behavior you explained could be replicated after your submission to Techincal Support. We will be reporting the behavior to Development to be addressed in a future release of JMP.
Thank you for helping us improve JMP.
It looks like this issue was successfully fixed in JMP 15 and later versions.
8 REPLIES 8
What Summary Statistic is selected in Graph Builder?  For certain statistics we attempt to provide extra precision.
Akane
Community Trekker
@josh_markwordt I used Summary Statistic 'N'.
Akane
Community Trekker
Gr1 = Data table ("AOI Log Summary")<<Graph Builder(
Size( 425, 348 ),
Legend Position( "Bottom" ),
Variables( X( :Date ), Y( :Count Error ), Overlay( :Error ) ),
Elements(
Dispatch(
"400",
ScaleBox,
This is part of script.
@Akane please open a track with Technical Support so we can help you investigate this report further. I am particularly interested in obtaining more information about your environment.
Akane
Community Trekker
@Dahlia_Watkins Hi, I opened a track with Technical Support. Please verify. Thank you.
Akane, Dahlia,
If this uses Summary Statistic( "N" ), it would be worth trying in JMP 14.2.
I fixed a similar bug, though I'm not sure this is the same case.
Heman.
