Our World Statistics Day conversations have been a great reminder of how much statistics can inform our lives. Do you have an example of how statistics has made a difference in your life? Share your story with the Community!
kartikhpatel
Cpk Analysis
Example   Dtata
98.8
99.7
99.7
99.9
99.5
100.0
100.4
98.8
99.3
100.5
100.4
100.5
100.2
100.4
101.5
100.7
100.7
100.4
99.7
100.3
100.4
101.2
101.2
100.0
99.7
100.3
101.4
101.0
100.5
Kindly Help For Above Data.
I want to find Within sigma estimated by moving range & Cpk. Please Help me.
louv
Staff (Retired)
Re: Cpk Analysis
If I assume that you are dealing with a one sided specification of >98% Assay for instance I can use either Quality and Process Control Chart Builder or an IR/MR control chart under the Analyze>Quality and Process platform.
Re: Cpk Analysis
I may have missed it, but do you have spec limits?
kartikhpatel
Re: Cpk Analysis
Sprc Limit is 98 to 102.
For Within sigma JMP is using which Constant?
d2=? 1.1.28 or any other?
louv
Staff (Retired)
Re: Cpk Analysis
kartikhpatel
Re: Cpk Analysis
Thank you Mr Lou Valente For Reply.
But My Question is For Within sigma JMP is using which Constant?
@Lou Valente
Steven_Moore
Re: Cpk Analysis
If I may add a point here:  If I assume your data is in time order (a requirement for a control chart), then you definitively have two populations in your data.  The first 9 data points comprise one population and the remaining 20 points comprise the second.  You can calculate Capability Indices for both populations separately, but to calculate a Capability for the entire data set is meaningless.  Any process must be in a "reasonable degree of statistical control" before one can calculate meaningful Capability Indices.  Your first question from this data set should be, "What happened to the process between somewhere around data points 9 and 10 that caused the process to shift upwards."  If the special cause of the shift is a good thing, you need to understand what the cause is and modify the system to make this permanent.
I hope this helps.
Steve
louv
Staff (Retired)
Re: Cpk Analysis
Steven_Moore
Re: Cpk Analysis
For individuals/moving range charts, you should always use the following formulas for computing limits:
Limits for Individuals chart = average ± 2.66 * average moving range
Upper limit for mR chart = 3.268 * average moving range
As Dr. Wheeler says in his articles on the right and wrong ways to do control charts, "Accept no other limits".
Steve
Article Labels
