doraemengs
Count value in multiple characters and mark position?
Hi, how can I count the number 0,1,2 from the 1 characteristic column as below? Thank you so much! (x = missing)
PatternCount 0Count 1Count 2Position 0Position 1Position 2
x,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 26 1 02,3,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,2840
2,2,2,2,2,0,0,0,0,0,0,1,1,1,2,0,1,1,1,2,2,2,0,0,0,0,0,0
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,0,1,1,1,1,0
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,0,0,0,1,0,1
2,2,2,2,2,2,2,2,0,2,2,2,0,0,0,1,2,2,2,2,2,2,2,2,2,2,2,2
13 REPLIES 13
doraemengs
Re: Count value in multiple characters and mark position?
Hi Jim,
Thank you so much, but when I try 1 and 2, it seems difficult due to a lot of data rows (6000+). The 3 dose not work because there are multiple patterns on it (2000 pattern of 28 positions in 6000 rows).
Best regards,
Theerachai
My misunderstanding. Now my response back to you is that I am sure JMP can do what you want.......if you can define the rules as to how to determine what a group is?
doraemengs
Hi Jim, Thank you, I try to combine the pattern of data. In general, my data positions 1-5, 6-9,10-11,12-17, 18-22, 23-25, and 26-28 are the same categories if they have the same 0-2 points (without fixing position in each category) in addition, sometimes, the categories would be 11-17, 1 5 6 8 13 18 23 26, 2 7 19 24 25 27 28, 3 9, 4 20 22, and 21. And I want to find other patterns in all the data. Could you please to guide me?
Thank you!
I remain confused.  You attached an example data table.  Would you please take a specific row(s) from the example data table and walk through the logic on how you would analyze the data from the row?
