Arthur
How to Pass Variables to the X Parameter in Fit Life by X?
Hi everyone,
I need to dynamically pass variables to the X parameter in the fit life by x function. The first part of my code generates the analysis report as expected, but the second part only brings up the startup window without a report.
Here’s what my code looks like:
dt = Open( "$sample_data/big class.jmp" );
x_var = "sex";
y_var = "weight";
obj1 = dt << Fit Life by X(
	Distribution( Weibull ),
	Nested Model Tests( Location and Scale ),
	Y( Eval(y_var) ),
	X( :sex ),
wait(2);
obj2 = dt << Fit Life by X(
	Y( :weight ),
	X( Eval(x_var) ),
Has anyone encountered this issue or knows how to correctly pass the variables to the X parameter?
Thanks!
peng_liu
Re: How to Pass Variables to the X Parameter in Fit Life by X?
Please see the following.
Because "Relationship" is missing, the codes is trying to make the best guess based on X. But at the place where the codes checks on X, X is not a valid column yet, in this case. So, providing complete information, the codes don't need to walk into the trap.
x_var = "sex";
y_var = "weight";
	Relationship( Location and Scale ),
	Y( Eval(y_var) ),
	X( :sex ),
wait(2);
	Y( :weight ),
	X( Eval(x_var) ),
This anomaly appears to be a bug. The Nested Model Tests argument is not recognized in the second case. Please report this to JMP Technical Support ([email protected]) so it can be entered as a defect and tracked.
This seems to require a bit more work to workaround as "normal" forcing won't work
dt = Open("$sample_data/big class.jmp");
x_var = "sex";
y_var = "weight";
myexpr = EvalExpr(dt << Fit Life by X(
	Y( :weight ),
	X(Expr(NameExpr(AsColumn(dt, x_var)))),
show(myexpr);
obj = Eval(myexpr);
One of the extremely rare cases where I would say to use Eval(Parse()) (evil parse) but this seems to work
x_var = "sex";
y_var = "weight";
obj2 = Eval(Parse(Eval Insert("\[dt << Fit Life by X(
	Distribution(Weibull),
	Nested Model Tests(Location and Scale),
	Y(:weight),
	X(:^x_var^)
Arthur
This is another workaround as well. Thank you!
peng_liu
x_var = "sex";
y_var = "weight";
	Y( Eval(y_var) ),
	X( :sex ),
wait(2);
	Y( :weight ),
	X( Eval(x_var) ),
Arthur
Oh, this is exactly the right answer. Thank you very much!
