See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
Count number of columns which have value
BhargavDS
I have a table where I want to create a new column which tells the number of cells in that row which has a value in it. How do I do this?
My columns look like this for example:
Name, A, B, C, D
I need to know how many in A,B,C and D have values in every row. Some rows have values for all of them, and in some none of them have values.
uday_guntupalli
Level VIII
Re: Count number of columns which have value
@BhargavDS
      I am assuming you have a table that looks like this :
  You can script your new formula like so :
If( Is Missing( :name ),0,1) + If( Is Missing( :age ), 0, 1 ) +
 If( Is Missing( :sex ), 0, 1 ) + If( Is Missing( :height ),0,1) +
If( Is Missing( :weight ),0,1)
Best
Uday
uday_guntupalli
Level VIII
@BhargavDS
Best
Uday
The below formula is a simpler form but gives the same results as @uday_guntupall
Sum(:Name == "", isMissing(:age),:sex=="",isMissing(:Height),isMissing(:Weight))
@uday_guntupalli
Thomas1
Did you try the following formula column?
N Missing( :A, :B, :C, :D )
