Xuhaidan
add data value
How to add all data value in graph? example time series graph.
gzmorgan0
Re: add data value
Is ths what you want (see picture below)? If yes, bring the table to the front
  • Select  the column used for your Y axis variable (in the example below Acid), by selecting it in the Column tabel panl or on the column header.
  • then Main Menu> Columns > select Label
  • Main Menu > Rows > Select > click on Select all rows
  • then Main Menu > Rows > click on Label. Each row in the table will now have a little tag icon showinh that is a label and each value is shown.
If this is not what you want, you need to provide more details.
