Hi All,
I struggle to calculate a "corrected mean" out of 4 result columns with continuous numerical values that I get.
How I define the "corrected mean"? I want to exclude the value which is the furthest away from the mean and double count the value closest to it (effectively replacing the excluded "outlier" with the value closes to it).
See example below where excluded values are highlighted in red and duplicated ones in green.
Thanks for your support! (I'm currently on JMP 17.0)
Please find script with the sample raw data below:
New Table( "corrected_mean_script",
Add Rows( 10 ),
New Column( "R1",
Numeric,
"Continuous",
Format( "Best", 12 ),
Color Cells( {36, {1, 10}} ),
Set Values( [50.7, 54.5, 53.7, 54.5, 51.4, 47.6, 50.8, 51.4, 47.1, 53.1] )
New Column( "R2",
Numeric,
"Continuous",
Color Cells( {{36, {3, 8}}, {3, {5, 6, 9}}} ),
Set Values( [49.2, 55.4, 51.3, 54.8, 55.3, 53.7, 51.6, 51.2, 51.8, 50.3] ),
Set Display Width( 48 )
New Column( "R3",
Numeric,
"Continuous",
Color Cells( {{3, {1, 2, 4}}, {36, {5, 7}}} ),
Set Values( [54.7, 50.3, 55.1, 51.3, 52.9, 48.2, 53, 52.8, 44.1, 51.6] )
New Column( "R4",
Numeric,
"Continuous",
Color Cells( {{36, {2, 4, 6, 9}}, {3, {3, 7, 8, 10}}} ),
Set Values( [50.3, 52, 49.8, 52.9, 50.5, 52.1, 54.3, 44.8, 48.6, 55.3] ),
Set Display Width( 50 )
