Jackie_
Optimize Assign values to selected rows
Hi JMP Community,
I wrote a jmp script to assign a string to the selected rows in the graph builder.
The script will generate a wafer map for the X and Y coordinates. Users can select a region of a wafer and assign a string to the selected rows.
The script works fine, but it takes a very long time to assign values to more than 10k selected rows. Am using :Column[rows] = "string" logic.
Is there a way to optimize or assign it faster? Any feedback?
Code:
dt = current data table();
New Window( "",
	modal,
	V List Box(
	hlistbox(
		Panel Box( "Assign",
			H List Box(
				Text Box( "Enter :" ),
				Spacer Box( size( 10, 0 ) ),
				tp = Text Edit Box( "", <<setwidth( 60 ) )
			Spacer Box( size( 10, 10 ) ),
			H List Box(
				Button Box( "Assign bin",
					ndies = N Items( dt << getselectedrows );
					Caption( "Processing... please wait", Font( "Arial Black" ), spoken( 0 ) );
					Wait( 0 );
					dt << label();
					getbin = tp << get text();
					rowind = dt << get selected rows;
					:Bins[dt << get selected rows] = getbin;
					Caption( "Assigned", Font( "Arial Black" ), spoken( 0 ) );
					Wait( 0.2 );
					Caption( remove );
					Wait( 0 );
		teb = Textbox()),
		dt << Graph Builder(
			Size( 534, 456 ),
			Show Control Panel( 0 ),
			Variables( X( :X coord ), Y( :Y coord ), Color( :Bins ) ),
			Elements( Points( X, Y, Legend( 5 ) ) ),
			Local Data Filter( Add Filter( columns( :Bins ), Where( :Bins == "1" ), Display( :Bins, N Items( 7 ) ) ) )
Craige_Hales
Re: Optimize Assign values to selected rows
Maybe this, but I did not see it being very slow, so maybe this isn't the problem:
						dt<<begindataupdate;
						dt<<enddataupdate;
Craige
Craige_Hales
						dt<<enddataupdate;
Craige
Jackie_
@Craige_Hales it works
