Aziza
Copy and paste tabulate output as picture in MS Word
Dear Community,
today my colleague showed me the case where she wanted to copy the tabulate results and paste it in MS Word as picture. It did not work unfortunately and the result of paste was just a column of numbers. We tried with PPT and it worked there. I could not help her and decided to ask you. Does anyone know how to do it?
Thank you and have great day!
Greetings
Re: Copy and paste tabulate output as picture in MS Word
1. Select what you wish to copy from tabulate with selection tool
2. Right click and select copy
3. In word use paste options and paste as picture
or from
This way you should get into word as a picture instead of table (table above and picture below)
Edit:
One good option when using Word (or Powerpoint/excel) is to use Paste Special and Picture (Enhanced Metafile) option
Some additional links:
https://www.jmp.com/en_be/learning-library/topics/jmp-basics/saving-publication-quality-graphics-wit...
Getting high-quality graphics out of JMP
P_Bartell
Level VIII
In addition to @jthi 's method, you could also use any manner of screen capture snipping tool. Depending on the OS on the colleague's machine there's probably one native to the OS install.
