shampton82
Copy Table Script vs Get Script
Hey everyone,
I would like to copy the data table script from a summary table that was made and paste the code for it back into a Parent level table so that for later analysis I can call up the table without having to have saved the actual table somewhere else.  Basically trying to streamline the user experience of having to save multiple tables files and then reopen a bunch of files to use the analysis later.
I was thinking it would be along these lines but this is not working.  dt1 would be the summary table and dt2 would be the parent table.
So this would copy the data table script of dt1 and then place it as a table script in dt2.
source_script = dt1 << Copy Table Script();
Eval(EvalExpr(
	dt2 << New Script("SourceFromSummary",
		Expr(Name Expr(source_script))
Any advice would be greatly appreciated!
Steve
Re: How to use Copy Table Script()
In that case, << Get Script should work for you
dt = New Table("ABC",
	Add Rows(10),
	New Column("A", Set Each Value(1)),
	New Column("B", Set Each Value(1)),
tablescript = dt << get script;
Eval(EvalExpr(
	dt << New Script("Create Copy", Expr(NameExpr(tablescript)));
If you really really wish to use Copy Table Script() (not sure why you would in case like this) use Get Clipboard() with Parse()
	Add Rows(10),
dt << Copy Table Script();
Eval(EvalExpr(
	dt << New Script("Create Copy", Expr(Parse(Get Clipboard())));
Do you wish to have the resulting Summary table or could you just utilize the script to create the summary table? Use << Get Script instead of Copy Table Script (it will copy it to clipboard)
dt_summary = dt << Summary(
	Group(:Age),
	subgroup(:sex),
	Mean(:Height),
	Include marginal statistics
summary_script = dt_summary << get script;
Eval(EvalExpr(
	dt << New Script("Summary", Expr(NameExpr(summary_script)));
shampton82
Hey @jthi ,
I was hoping to have the resulting table.  The summary table being created is from a "make into data table" function and I'd like to be able to pull up the resulting table at a later time without having to rerun the analysis (which happens if I grab the embedded source table script).
	Add Rows(10),
Eval(EvalExpr(
	Add Rows(10),
Eval(EvalExpr(
shampton82
Nice!
I didn't realize that I could just use get script, I was trying to copy the red arrow action of copy table script so that was what I found in the scripting index.
Side question, is there a way to make a table a "child" of a parent table (like when you make a summary table and then link it)
This would allow that when you close the parent table it will close the main table as well as be able to collapse the tables in the home window.
To create "child tables" I think they have to be linked -> you would need to utilize Summary function instead of copying the table script with Link to Original Table(1). Other option would be to modify the table script and add << On Close to the original table when the table script is run but it can be difficult to make sure it will always point to the correct (original) table as Current Data Table() might not work as you think it will. Other thing you would have to take care of would be to keep on close script up to date when more and more tables are being created. For this you could manage the "references" with On Close via table variables or try to use << get on close to pull in last on close script and combine it with new table to close with.
You could also utilize Subscribe to Data Table List maybe with specific table names to know which ones to with the main table.
