Florent_M
Random data from a factor table without using Fast Flexible Filling Design
Hello!
Is there an easy way to make random data from a factor table (the thing used to define factors in the DoE platform) without using Fast Flexible Filling Design? Fast Flexible Filling Design starts to become very slow after 1,000 runs.
I would really appreciate any suggestions.
Best wishes,
Victor_G
Re: Random data from a factor table without using Fast Flexible Filling Design
Hi @Florent_M,
If I understand your question correctly, having faced a similar situation, here is what I have done :
  • Create a very simple DoE based on your factors table, and add a dummy response variable
  • Create a model of the dummy response variable based on your factors
  • Use the Simulator option from the Profiler and specify the type of distribution you would like to create for your different factors
  • You can then specify the number of runs you want and create a Simulation table (the design behind is a Latin Hypercube).
Perhaps a more direct option with your factors table : https://www.jmp.com/support/help/en/18.0/#page/jmp/example-of-simulating-general-formulas.shtml#ww51...
Hope I understood your topic and that this option makes sense for your needs ?
Victor GUILLER
Victor_G
Hi @Florent_M,
Victor GUILLER
Florent_M
Hi @Victor_G !
Thanks for the tip, even if the method isn't the most direct and the graphical interface isn't the most user-friendly, it works!
Best regards,
Florent
