Sebastienlg
Control chart - K sigma set up
I would like to make a control chart with a KSigma set up by a coefficient automatically calculated.
Below is my code:
graph = New Window( chart_title,
Control Chart(
Sample Label( :Numéro de lot ),
Sample Size( :N ),
KSigma( z_KSigmaZ ),
Sort by Row Order( 1 ),
Chart Col( :"Y1"n, P( Limits Precision( 1 ), LCL( -3 ) ) ),
However, by setting up the coefficient with this code:
it doesn't work and 3 is always applied as coefficient...
Is someone has an idea to help me with this?
Regards,
Sebastien
ian_jmp
Level X
Re: Control chart - K sigma set up
Perhaps something like this:
NamesDefaultToHere(1);
ksVal = 2;
// 'Template' expression to make a Control Chart
makeCC = Expr(cc = dt << Control Chart( Sample Label( :age ), KSigma(TBD), Chart Col( :height, XBar, R ) ));
// Subsitite the required value into 'makeCC'
SubstituteInto(makeCC, Expr(TBD), ksVal);
// Evaluate the resulting expression
makeCC;
ian_jmp
Level X
ksVal = 2;
makeCC;
Sebastienlg
Great! It's working! Thank's a lot for your answer :)
