WebDesignesCrow
How to Select Rows with Date < number of days from Today
My data table contain 90 days of data (e.g 03/01/2022 to 03/04/2022).
(The min & max date are not fixed because my source file will be updated daily with latest 90 days from today)
I only need latest 30 days of data in my data table for 1 type of analysis.
(e.g I want to retain rows with date from min=03/03/2022 to max=03/04/2022)
So, I want to select rows with End date > 30 days & delete it.
I used lines as below but it didn't work.
//Remove data with End date  < Today - 30 days (not required for analysis)
Current Data Table() << Row Selection( Select where( :End date < (Today () - in days(30)  ))) << delete rows;
I check the log, it shows that the line is scriptable but I don't see any changes on my data table.
Any advice?
I'm using JMP15
Re: How to Select Rows with Date < number of days from Today
There appears to be a bug in JMP 15 with the Row Selection() function.  You can get what you want by just using the Select Where()
Current Data Table() <<  Select where( :End date < (Today () - in days(30)  )) << delete rows;
It has been fixed in JMP 16
In cases like this I prefer using Date Difference (jmp.com) as it manages time / different intervals usually better. It might require some tries to get it working correctly (play around with alignment) but in my opinion it is worth it
row_count = 40;
dt = New Table("dates",
	Add Rows(row_count),
	New Column("End date",
		Numeric,
		Continuous,
		Format("Format Pattern", "<YYYY><-><MM><-><DD> <hh24><::><mm><::><ss>", 19, 0),
		Input Format("Format Pattern", "<YYYY><-><MM><-><DD> <hh24><::><mm><::><ss>", 0),
		<< Set Each Value(Today() - In Days(row_count - Row()))
dt << New Column("difference", Numeric, Continuous,
	<< Formula(Date Difference(:End date, now, "Day"));
WebDesignesCrow
Thanks Jim. Problem solved ! I overthink on writing the line.
