swiergi11
Control Panel for multiple scripts
Just wondering is there some sort of control panel I could create for my scripts so they all can be run with push of the button externally from script itself?
I have close to 50 scripts which in total create ~150 control charts and I was wondering if I could use some application where I can sort those scripts based on the set criteria and run them  all at ones and not to go to all 50 of them one by one.
Thanks T
ih
Super User (Alumni) ih
Re: Control Panel for multiple scripts
You can use the include() function to read and execute another jsl file.  An add-in to would let you package the scripts together makingit easy to share them with others and you could create a single script which could call all of the others.
Include( "$SAMPLE_SCRIPTS/chaosGame.jsl" );
To create an Add-in I suggest using the Add-In Manager.
swiergi11
thank a lot
