BookmarkSubscribe
guleiss
Community Trekker
Contour plot weird problem
I used JMP for a few years and recently got a strange problem during a contour plot. Please see attached JMP file (test.jmp).
The data was plotted correctly in matlab. In the attached file, if I just plotted freq from 0.2 to 0.8, everything looked good (as left image). But if I included freq=0.9, the plot is changed completely (actually, the plot shrunk to a single line, as right image). I also noticed even I didn't add new data, but changed the exist data slightly, the plot was changed completely to a line, i.e. I changed one data freq from 0.8 to 0.9. It's so weird to me.
Can anyone give me a help?
Thanks a lot!
-Lei
13 REPLIES 13
DaveLee
Community Trekker
Re: Contour plot weird problem
I ran the same analysis and extended the x-axis to include 0.9 and got a nice looking plot.  What version of JMP are you using?  I'm using v12.  Perhaps you accidentally rescaled the y axis as well.
guleiss
Community Trekker
Thanks, I reinstall the JMP12. It seemed the problem solved.
guleiss
Community Trekker
Hi, dlee0416,
Sorry, I might draw my conclusion too soon. After JMP re-installation, I actually still got the problem. In your plot, the column1 is still from 0.2 to 0.8. Can you please try add 0.9 data and see if you have similar problem?
Thanks,
-Lei
DaveLee
Community Trekker
Guleiss,
I plotted the data you provided and there is no data >0.8. In my original plot I just manually changed the axis settings.
DaveLee
Community Trekker
Here's the code to do this in JSL:
Contour Plot(
    X( :Column 1, :Column 2 ),
    Y( :Column 3 ),
    Show Data Points( 0 ),
    Fill Areas( 0 ),
    Label Contours( 0 ),
    Transform( "None" ),
    Specify Contours(
        Min( 5 ),
        Max( 35 ),
        N( 7 ),
        Contour( 1, 5, -2380261 ),
        Contour( 2, 10, -1998002 ),
        Contour( 3, 15, -1285756 ),
        Contour( 4, 20, -58112 ),
        Contour( 5, 25, -7246852 ),
        Contour( 6, 30, -12018696 ),
        Contour( 7, 35, -16125962 )
    SendToReport( Dispatch( {}, "1", ScaleBox, {Max( 0.9 )} ) )
guleiss
Community Trekker
Hi dlee0416,
Thanks for your reply. Sorry, I forgot to mention I excluded 0.9 data in the .jmp file. It makes curve looks weird. They are actually in the .jmp file. Please help. I also tried these data with excel contour plot and looked good.
Thanks,
-Lei
DaveLee
Community Trekker
Guleiss,
I see your problem. I have tried to create a meaningful contour plot and for some unknown reason I get the same result when adding the 0.9 data.  I'm attaching a jmp file showing several plots that definitely show the data and the surface.  I even used another program and got a very nice contour map.  I think you might have stumbled into a bug. I'd suggest contact Technical Support.  Sorry I couldn't be of more help.  Please let me know or private message when the final 'fix' is determined.
Dave
guleiss
Community Trekker
Hi dlee0416,
Thanks for your time to look into it.It's just weird. I never have this problem before. Other tools like matlab or excel are fine with this contour plot. Thanks for your suggestion. I may submit a technical support as a bug.
Thanks,
-Lei
louv
Staff (Retired)
Hi L.
I see the same funny behavior as you do when I un-exclude the 0.9 rows using the Graph>Contour Plot platform. Tech support should be alerted.
When I Fit Model with Column 3 as the response and Column 1 and Column 2 as factors I am able to get the contour plot
