gandi2223
Contour plot, set X and Y ranges in JSL
When creating a contour plot in JSL, is there a way to set fixed (pre-determined) values for the X and Y maximum and minimum? I.e. to define the area the contour plot will cover, as can be done manually in the X / Y Axis Settings dialogue?
My datasets cover different ranges in x and y, but I would like all contour plots to have the same x and y extents.
Something like:
Contour Plot(
	X( :X_col, :Y_col ),
	Y( :data ),
	X_minimum(-75000),
	X_maximum(75000)
(This obviously does not work.)
10 REPLIES 10
Jeff_Perkinson
Re: Contour plot, set X and Y ranges in JSL
An easy way to do this might be to set the Axis Property for your X and Y columns. That will ensure that every plot made with those columns has the scaling that you want.
-Jeff
