Neo
Neo
How to have custom X-Y grid spacing in a plot?
In the plot generated by the example script below, how do I have a custom grid say spaced 25 apart on both X & Y axis (and color the grid lines with a chosen color and increase line width of the grid lines)?
dt = Open( "$SAMPLE_DATA/Little Pond.jmp" );
dt << Contour Plot(
	X( :X, :Y ),
	Y( :Z ),
	Show Data Points( 0 ),
	Fill Areas( 0 ),
	Label Contours( 0 ),
	Transform( "Range Normalized" ),
	Specify Contours( Min( -4 ), Max( 8 ), N( 7 ) ),
		Dispatch(
			"1",
			ScaleBox,
			{Label Row( {Show Major Grid( 1 ), Show Minor Grid( 1 )} )}
		Dispatch(
			"2",
			ScaleBox,
Right clicking on the generated chart and looking at the customize option does not give me desired options.
Thanks.
When it's too good to be true, it's neither
MathStatChem
Re: How to have custom X-Y grid spacing in a plot?
Here is a modified script that does everything you want, except the adjusting the width of the grid lines
cont_plot = dt << Contour Plot(
	X( :X, :Y ),
	Y( :Z ),
	Fill Areas( 0 ),
report(cont_plot)[axis box(1)]<< show major grid(1);
report(cont_plot)[axis box(2)]<< show major grid(1);
report(cont_plot)[axis box(1)]<< inc(25);
report(cont_plot)[axis box(2)]<< inc(25);
report(cont_plot)[axis box(1)]<< Major Grid Line Color("red");
report(cont_plot)[axis box(2)]<< Major Grid Line Color("red");
I cannot see a way to adjust the thickness of the axis gridlines.  One hack to do this would be to add reference lines  the grid line levels.
	X( :X, :Y ),
	Y( :Z ),
	Fill Areas( 0 ),
for each({val}, 0::400::25,
	report(cont_plot)[axis box(2)]<<Add Ref Line(val, "Solid", red, "", 3)
for each({val}, 0::150::25,
	report(cont_plot)[axis box(1)]<<Add Ref Line(val, "Solid", red, "", 3)
MathStatChem
	X( :X, :Y ),
	Y( :Z ),
	Fill Areas( 0 ),
	X( :X, :Y ),
	Y( :Z ),
	Fill Areas( 0 ),
