rg1494
Continuous fit
Some data is not Normal distribution, and i can't transform with Box-Cox. Can I use Distributions_Confinuous Fit_All ?
Re: Continuous fit
Yes.  The Distribution Platform has the capability of transforming  non normal distributed data to a normal distribution.  I suggest that you read about the Distribution Platform in the Basic Analysis document from the JMP Documentation Library, available under the Help pull down menu.
Re: Continuous fit
rg1494
Re: Continuous fit
Thanks!  But Documentation is just a brief introduction to each distribution. Such as the Normal Mixtures distribution fits a mixture of normal distributions(This flexible distribution is capable of fitting multi-modal data. You can also fit two or more distributions by selecting the Normal 2 Mixture, Normal 3 Mixture, or Other options.). i expect to know when we can choose 2 Mixture or 3 Mixture and whether the more modes to choose, the better.
