Hi @mjz5448,
I think the JMP Help page related to Power Analysis may help you.
If your DoE response is Yield (expressed in %), then I would complete the Power analysis with the following informations :
- Significance level : To be adjusted accordingly to your study, objectives, research stage, ...
- Anticipated RMSE : Noted at 5 (or 0,05 depending on you write percentage, like maximum at 100% or at 1).
- Anticipated coefficient : Since you want to detect at least 7% increase/decrease of the response due to the factors change, I understand that between the low and high levels of each factor, Y could increase to 7% (or more). So the anticipated coefficient would be 3,5 for all your factors in this situation (since the anticipated coefficient represent the change in the response between mid and high or low levels of the factor). Don't forget to click on "Apply Changes to Anticipated Coefficients" once you have written the values so that the calculations of power can be updated.
 If yes, here is what the power analysis results would look like on the dataset "Extraction2 Data" with these infos :
You might also find some useful discussions and tips in the following posts :
Should I consider power analysis in DOE?
How to get RMSE of the Power analysis for DOE
	Victor GUILLER
