BookmarkSubscribeRSS Feed
mad
Jun 23, 2011
Conditionally Concatenate Data Tables
Is it possible, in a jmp script, to concatenate data tables (vertically) and conditionally specify which rows get sent to the new data table?
ex. Concatenate(dt, Where( :row == 5))
mpb
Jun 23, 2011
Re: Conditionally Concatenate Data Tables
I don't think so.I believe you'll have to (using scripting) select the rows you want in a given table and create a subset table having only those rows which you can then use in concatenation.
