bzanos
Concatenate selected row from multiple subsetted data tables into 1 new data table
I have a data set(as example, Big Class) that contains all the data. I subset the data by age and select first row of each
subsetted data table. Then, I subset it again so that I can do concatenation of the selected row data into new table.
I notice that there is additional data (unwanted data ) concatenated in the new table (highlighted in red rectangular).
I am not sure what is the problem of my script.
I attach my script in below.
I really appreciate if anyone could help me to fix this issue.
// Open Big Class data table
//Subset the data table by age
listDT = dt << Subset(
	By( :age ),
	All rows,
	Selected columns only( 0 ),
	columns( :name, :sex, :height, :weight )
//Select first row of each subset data table
For( i = 1, i <= N Items( listDT ), i++,
    listDT[i] << Select Rows( {1} );
    listDT[i] << Subset("");
    Close(listDT[i],"No Save");
    Close(dt,"No Save");
// Create Tables list
Tables = {};
For( i = 1, i <= N Table(), i++,
	Insert Into( Tables, Data Table( i ) << get name );
//Create new table
New Table("FirstRowData");
// Run the concatenations
For( i = 1, i <= N Items( Tables ), i++,
	 Data Table( "FirstRowData" ) << Concatenate(
		Data Table( Tables[i] ),
		append to first table(1)
	Close( Data Table( Tables[i] ), No Save );
Re: Concatenate selected row from multiple subsetted data tables into 1 new data table
The issue here seems to be the table variables that were created for each subset.  Table variables with the same name ("age") were then getting added as columns with each concatenation.  See script below, and notice the For-loop added to delete the table variables.  Does this resolve the issue for you?
	By( :age ),
	All rows,
Tables = {};
//Delete table variables
	Data Table(Tables[i]) << Delete Table Variable("age");
//Create new table
	By( :age ),
	All rows,
Tables = {};
//Create new table
bzanos
Thank you!
It works perfectly
