PF
PF
Comparing datasets from two different files
Hi Everyone
I need a little help to get past this.
I have two datasets in two different files. I need to compare multiple columns in the two files and then get the data which is exactly the same in a new file. I thought about loops but I don't know if JMP scripts can do that?
ian_jmp
Level X
Re: Comparing datasets from two different files
I think you are asking for a JSL script, and 'yes' you can use loops. It's usually good practice to let JMP generate code for you and then build on that. With that in mind, I would try playing with Compare Data Tables interactively with some of your data and see where that leads you. Be aware there are many ways one could approach this problem.
ian_jmp
Level X
PF
PF
I tryed different things, but the joining by matching variables was the best way for me.
triunk
Hi Ian,
I am afraid the link of the phrase "compare data tables" does not work
Might you be able to redirect us to the right link?
Jeff_Perkinson
I've updated the link in the post above.
-Jeff
triunk
Thank you for the update
