Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
I have two datasets in two different files. I need to compare multiple columns in the two files and then get the data which is exactly the same in a new file. I thought about loops but I don't know if JMP scripts can do that?
Created:
Sep 27, 2017 04:14 AM
| Last Modified: May 1, 2018 10:38 AM(11033 views)
| Posted in reply to message from PF 09-27-2017
I think you are asking for a JSL script, and 'yes' you can use loops. It's usually good practice to let JMP generate code for you and then build on that. With that in mind, I would try playing with Compare Data Tables interactively with some of your data and see where that leads you. Be aware there are many ways one could approach this problem.
Created:
| Last Modified: May 1, 2018 10:38 AM(11034 views)
