Dennisbur
Columns locked
Hello
Some of the columns are locked,
If I have any option to convert the columns to open one without doing once again a summary and removing the "link to the original data table"?
Victor_G
Re: Columns locked
Hello @Dennisbur,
@txnelson has provided a solution on this topic in this post : Solved: How do I unlock a column? - JMP User Community
I hope this will help you,
Victor GUILLER
Re: Columns locked
Quickly, right click on column you want to unlock, select Column Info>uncheck the Lock box.
Re: Columns locked
If you are using JSL, you can use the code below to unlock a table and all columns in it:
			dt << Lock Data Table( 0 );
			For( j = 1, j <= N Col( dt ), j++,
				Try( Column( dt, j ) << lock( 0 ) )
Cheers,
Brady
