ericx
Column switcher in JMP 16
I'm following the video linked here about the column switcher function in JMP, but I don't see that option in my JMP... I have JMP 16 installed, and I only have the Save Script option, I don't see a menu for just Script.
Is there something I'm missing?
Thanks.
Re: Column switcher in JMP 16
In JMP 16, Graph Builder, the Column Switcher is available under the Red Triangle @
     Redo=>Column Switcher
BHarris
Surprisingly hard to find and remember.  Why remove it from the Mac toolbar?
Here are some other options...
On Windows, if you have the toolbar visible, you can click on the Column Switcher button.
if you are building a Dashboard or JMP Application, you can drag the Column Switcher from under Boxes to the report and have it affect multiple graphs!
Read more about editing Dashboards here: https://www.jmp.com/support/help/en/16.1/?os=win&source=application&utm_source=helpmenu&utm_medium=a...
 Enjoy switching columns.
~John
ericx
Thank you :)
