ericx
Column switcher in JMP 16
I'm following the video linked here about the column switcher function in JMP, but I don't see that option in my JMP... I have JMP 16 installed, and I only have the Save Script option, I don't see a menu for just Script.
Is there something I'm missing?
Thanks.
Re: Column switcher in JMP 16
In JMP 16, Graph Builder, the Column Switcher is available under the Red Triangle @
     Redo=>Column Switcher
BHarris
Surprisingly hard to find and remember.  Why remove it from the Mac toolbar?
John_Powell_JMP
Here are some other options...
On Windows, if you have the toolbar visible, you can click on the Column Switcher button.
if you are building a Dashboard or JMP Application, you can drag the Column Switcher from under Boxes to the report and have it affect multiple graphs!
Read more about editing Dashboards here: https://www.jmp.com/support/help/en/16.1/?os=win&source=application&utm_source=helpmenu&utm_medium=a...
 Enjoy switching columns.
~John
ericx
Thank you :)
