Column is missing from GR&R table
Hi
I am working with the GR&R analysis tool and need to get the % of Tolerance column in the results table. Something like this
But when I right-click on the Gauge R&R to show this column, the only available columns to are these items
Do you have any idea how to get the % of Tolerance column?
Thank you
Re: Column is missing from GR&R table
You need to specify the tolerance range prior to running the Measurement System Analysis.
https://www.jmp.com/support/help/en/17.0/?os=mac&source=application#page/jmp/the-type-1-gauge-study-...
