Onjai
Column filling
I have a table of data containing several hundred rows and need to create a column that is filled with incremental numeric values, the twist is that I require the incremental fill to follow as below:  The column is called "sample" and row 1 value = 1, row 2 value = 1, then increment by 1, so that row 3 value = 2, row 4 value = 2 and continue to the end of the data file.
 sample
 1
 1
 2
2
 3
 3
 4
 4
 5
Any thoughts?
e 5
s 6
e 6
s 7
Jeff_Perkinson
Re: Column filling
Try the Sequence() function.
-Jeff
Onjai
Re: Column filling
Please ignore the last few lines of my post...those should not have been sent.
Thank you
uday_guntupalli
Level VIII
Re: Column filling
You should be able to use Lag() function to get what you want .
Can you provide a screenshot of the exact output you are after ?
Best
Uday
Jeff_Perkinson
Re: Column filling
-Jeff
Onjai
Re: Column filling
Jeff,
Thank you.  Sequence worked perfectly.
Cheers!
