ComplexNerd
Column Switcher Appled to All Open reports
Hi guys,
I am trying to write a script to apply column switcher to all open reports. Please guide me
dt = Current data Table();
//Get all Open reports
wList = Get Window List( Type( "Reports" ) );
//Get Column to replace and column to replace with
win = New Window( "Set a Value",
	<<Modal,
	<<Return Result,
	H List Box(
		ColumnSwitcherObject = dt << Column Switcher(),
		colList = dt << Col List Box()
	Button Box( "OK" ),
	Button Box( "Cancel" )
//Now i want to loop through all reports and check if data table matches then replace column with selected column
If( win["Button"] == 1,
for(i=1,i <= nitems(wList),i++,
	curWin = wList[i][Outline Box( 1 )][Outline Box( 1 )];
	curWinObj = curWin << get scriptable object;
	curWinDt = curWinObj << Get Datatable;
		if (curWinDt == dt )
			//Replace all istance of column in list box of widow and col switcher
Please guide how to do this action.
Thanks in advance
Re: Column Switcher Appled to All Open reports
There seems to be few different bugs/weird interactions which are making this more difficult than I thought and because of that the code is very messy, but it seems to work on some level
get_reports_for_datatable = function({dt}, {Default Local},
	valid_reports = {};
	// This might need improvements
	report_windows = Get Window List(Type("Reports"));
	For Each({report_window}, report_windows,
		Try(
			cur_analytic_layer = report_window[OutlineBox(1)] << Get Scriptable Object;
			cur_dt = cur_analytic_layer << Get Data Table;
			If(cur_dt == dt,
				Insert Into(valid_reports, cur_analytic_layer);
			show(exception_msg);
	return(valid_reports);
// I would use function, but there seem to be some bugs
swap_report_columns = Expr(
	Eval(EvalExpr(
		nw_switcher = New Window("Switcher", << Window View("Invisible"),
			vlb2 = V List Box(
				ref_colswitcher2 = dt << Column Switcher(Expr(NameExpr(AsColumn(dt, old_col))),
					{Expr(NameExpr(AsColumn(dt, old_col))), Expr(NameExpr(AsColumn(dt, new_col)))}
	Batch Interactive(1);
	For Each({report, idx}, report_list,
		//report = report_list[2]
		nw1 = New Window("", << Window View("Invisible"),
			ref_colswitcher1 = dt << Column Switcher(Expr(NameExpr(AsColumn(dt, old_col))),
		lc = Log Capture(ref_colswitcher1 << Link Platform(report));
		ref_colswitcher1 << Remove Column Switcher;
		nw1 << Close Window;
		If(Is Missing(lc),
			Log Capture(
				Try(ref_colswitcher2 << Link Platform(report));
		wait(0);
	Batch Interactive(0);
	Try(vlb2[ListBoxBox(1)] << Set Selected(2));
	wait(0);
	ref_colswitcher2 << Remove Column Switcher;
	Caption(remove);
	nw_switcher << Close Window;
swap_columns = Expr(
	nw = New Window("Swap report columns", << Type("Launcher"),
		window:dt = Current Data Table(),
		H List Box(
			Lineup Box(N Col(2),
				Panel Box("Select Column to Change",
					fcs1 = Filter Col Selector(dt, << Set Max Selected(1))
				Panel Box("Select New Column",
					fcs2 = Filter Col Selector(dt, << Set Max Selected(1))
			Panel Box("Action",
				Button Box("Change Columns",
					report_list = get_reports_for_datatable(dt);
					old_col = (fcs1 << get selected)[1];
					new_col = (fcs2 << get selected)[1];
					Try(swap_report_columns);
				Button Box("Cancel",
					fcs1 << close window;
dt = Open("$SAMPLE_DATA/Probe.jmp");
dt << Clear Row States;
dist = dt << Distribution(Continuous Distribution(Column(:DELL_RPNBR)));
dist2 = dt << Distribution(Continuous Distribution(Column(:DELW_M1)));
gb1 = dt << Graph Builder(
	Size(528, 448),
	Show Control Panel(0),
	Variables(X(:Site), Y(:Lot ID)),
	Elements(Points(X, Y, Legend(3)))
gb2 = dt << Graph Builder(
	Size(523, 454),
	Variables(X(:DELW_M1), Y(:DELL_RPNBR)),
swap_columns;
Write();
How do you wish to use Col List Box? Column Switcher requires you to have a single column which is then changed to other column (based on the column list on Column Switcher) and this column should be the same in all of the reports at the start.
ComplexNerd
@jthi , My bad im sorry.. I guess instead of column switcher its more esay to have 2 colList Box where user selects column to replace in 1st and column to replace with in 2nd.. Is this approach more suitable
I think that might be a bit easier. I don't have time to write proper solution, but below is an idea how I would approach this (use column switcher to change columns which you create on function call + "Ask forgiveness, not permission"). It still has hard-coded things in it, but I will get back to it later today or tomorrow and make it more robust as this is interesting problem.
New Window("",
	Lineup box(N Col(2),
		dist = dt << Distribution(Continuous Distribution(Column(:DELL_RPNBR))),
		dist2 = dt << Distribution(Continuous Distribution(Column(:DELW_M1))),
			Size(528, 448),
			Size(523, 454),
nw = New Window("",
	H List Box(
		Panel Box("Action",
			Button Box("Change Columns"),
			Button Box("Cancel"),
update_reports = function({dt, report_list, old_col, new_col}, {Default Local},
	nw_switcher = New Window("", << Window View("Invisible"),
		ref_colswitcher = dt << Column Switcher(:DELL_RPNBR, {:DELW_SICR, :DELL_RPNBR});
	wait(0);
	For Each({report}, report_list,
		Try(ref_colswitcher << Link Platform(report));
	wait(0);
	nw_switcher[ListBoxBox(1)] << Set Selected(1);
reports = Eval List({dist, dist2, gb1, gb2});
update_reports(dt, reports, "a", "b");
	valid_reports = {};
		Try(
			If(cur_dt == dt,
	Eval(EvalExpr(
			vlb2 = V List Box(
		If(Is Missing(lc),
			Log Capture(
		wait(0);
	wait(0);
	Caption(remove);
		H List Box(
			Panel Box("Action",
	Size(528, 448),
	Size(523, 454),
swap_columns;
Write();
