JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
Column Formula to display difference between two rows of another column
May 4, 2011 01:05 PM(25411 views)
My data set is-
Vg Ig Igs 0 1 1 1 5 4 2 7 2 3 3 -4
I would like to create column Igs which is difference between current row and previous row in the column Ig. Is it possible script something like this in jmp.
Both the solutions given here work well. I have data that is similar, but in a date format. I want to calculate the difference between rows where the differences are in units such as 'day' or 'year' or 'week' or 'months'. Is there a way to do this?
I am using bivarate plot and adding a fit line. I would like to save slope and intercept values in a text file. I am using following code:
biv=rbiv<Ex1=biv[NumberColBox(13)][2]; show(Ex1);
Show(Ex1) show the value of slope in the log file along with the log of entire session. Is it possible to send JSL command to save the values of just slopes and intercepts in to a new data table or seperate text file from the log.
Thank you
Regards, Chivukula
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '3313' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '3313') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '3313') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
