dougguthe
Default color palette for hierarchical clustering
Somehow I have changed the default color palette for changing the colors of the clusters. How can I adjust the color palette used in hierarchical clustering?
I am using this to teach a class and display geographical clustering using latitude and longitude for the San Francisco Crime dataset. For whatever palette got chosen there isn't enough of a difference in the colors between the clusters to effectively display the changes in cluster size as you change the number of clusters.
Re: Default color palette for hierarchical clustering
I assume the color pallet is coming from the Preferences...…
File==>Preferences==>Graphs
dougguthe
Thank you very much, that did fix my problem. I had selected Viridis at some point and when you have a categorical variable with only two categories, the colors were too similar. I was able to select another sequence of colors for categorical variables.
