Hi @ian_jmp
I wrote the following code.
dlg = Column Dialog(
			name = ColList( "Name", Min Col(1), Max Col( 1 ) ),
			subject = ColList( "Subject", Min Col(1) ),
		If( dlg["Button"] == 1,
			name = dlg[ "name" ];
			subject = dlg["subject"]
So, After run, when I print the name, it prints ":A". It refers to the whole column but I want to get only the column name. How I can resolve the issue. Also sometime if I am working with multiple data tables it shows error can't access column 'A' because the row number (0) is not valid.
Please help how I can resolve this issue.
Thanks
