Fatemeh_2020
Resampling form the collected data
Hello! Can any one help?
I am collecting data through an online survey. My survey includes ranking questions. For analysis, the answers to the ranking questions will be replaced by the numbers 1 to 5. In other words, my data type is ordinal.
So far, 6 participants answered each question. At this stage, I must simulate how a larger number of participants (totally 20 or 30 participants) answer the ranking questions.
1) Is resampling from the data collected from the 6 participants an appropriate method to simulate how totally 30 participants answer the ranking questions?
2) If yes, how I can resample from the current data using JMP?
Thank you in advance.
KarenC
Re: Resampling form the collected data
Truthfully, you have 6 responses. That might represent what you will see when you get to 30 (still a very small N for survey work) or it might not. Your best guess right now is what you see in the 6, you could resample/simulate but after many rounds you will be back to about what you see in the 6 and that provides very little insight at this point.
KarenC
Fatemeh_2020
Thank you very much for the clarification.
