pankajsync
Column Custom Formula
I would like to add a new column 'Vth' in my table with the following calculation:-
First I need to find the index i of column 'Id' where the 'Id' is nearest to 1e-6; and then Vth = Vg(i). It should be grouped by Mod and Device columns as well. That is, each unique combination of Mod and Device will have one Vth value.
IdVgModDeviceVth
2.00E-0631AX1
2.00E-072.81AX1
2.00E-082.61AX1
2.00E-092.41AX1
2.00E-102.21AX1
2.00E-1221AX1
3.00E-0631BX1
3.00E-072.81BX1
3.00E-082.61BX1
3.00E-092.41BX1
3.00E-102.21BX1
3.00E-1221BX1
4.00E-0631AY1
4.00E-072.81AY1
4.00E-082.61AY1
4.00E-092.41AY1
4.00E-102.21AY1
4.00E-1221AY1
5.00E-0631BY1
5.00E-072.81BY1
5.00E-082.61BY1
5.00E-092.41BY1
5.00E-102.21BY1
5.00E-1221BY1
Re: Column Custom Formula
Here is a little script that create 2 new columns that gives you the results you asked for.  The image below has had the interim column deleted since it is only a working column.
Names default to Here(1);
// Create the sample data table
dt=New Table( "Example",
	Add Rows( 24 ),
	New Column( "ID",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values(
			[0.000002, 0.0000002, 0.00000002, 0.000000002, 0.0000000002,
			0.000000000002, 0.000003, 0.0000003, 0.00000003, 0.000000003,
			0.0000000003, 0.000000000003, 0.000004, 0.0000004, 0.00000004,
			0.000000004, 0.0000000004, 0.000000000004, 0.000005, 0.0000005,
			0.00000005, 0.000000005, 0.0000000005, 0.000000000005]
	New Column( "VG",
		Numeric,
		"Continuous",
		Set Values(
			[3, 2.8, 2.6, 2.4, 2.2, 2, 3, 2.8, 2.6, 2.4, 2.2, 2, 3, 2.8, 2.6, 2.4,
			2.2, 2, 3, 2.8, 2.6, 2.4, 2.2, 2]
	New Column( "Mod",
		Character( 16 ),
		"Nominal",
		Set Values(
			{"1A", "1A", "1A", "1A", "1A", "1A", "1B", "1B", "1B", "1B", "1B", "1B",
			"1A", "1A", "1A", "1A", "1A", "1A", "1B", "1B", "1B", "1B", "1B", "1B"}
	New Column( "Device",
		Character( 16 ),
		"Nominal",
		Set Values(
			{"X1", "X1", "X1", "X1", "X1", "X1", "X1", "X1", "X1", "X1", "X1", "X1",
			"Y1", "Y1", "Y1", "Y1", "Y1", "Y1", "Y1", "Y1", "Y1", "Y1", "Y1", "Y1"}
// Find the index
dt << New Column("Row", formula(
theMin = Col Minimum( Abs( 0.000001 - :ID ), :Mod, :Device );
theValue = .;
If( Abs( 0.000001 - :ID[Row()] ) == theMin,
	theValue = Row()
// Set the Vth
dt<<New Column("Vth", formula(
theRow = :VG[Col Max( :Row, :Mod, :Device )]));
// Clean up
dt:Vth << delete formula;
dt<< delete columns("Row");
pankajsync
Thanks Jim. It works. How can I modify this to find the Vth which corresponds to exactly 1e-6 of ID by interpolation. I.e. finding an index before and after 1e-6 of ID and then interpolate.
index=nearest to 1e-6 (greater than 1e-6)
Interpolate( x, [VG(index) VG(index-1)  ], [log10(ID(index))  log10(ID(index-1))] );
Here are the columns to generate what you are asking for.  I took your interpolation formula as is, and implemented it.  You may need to changes some things up.
	Add Rows( 24 ),
	New Column( "ID",
		Numeric,
		"Continuous",
		Set Values(
	New Column( "VG",
		Numeric,
		"Continuous",
		Set Values(
	New Column( "Mod",
		Character( 16 ),
		"Nominal",
		Set Values(
		Character( 16 ),
		"Nominal",
		Set Values(
// Find the index
theValue = .;
	show(.000001 - :ID[Row()]);
	theValue = Row()
dt<<New Column("Interpolation Row", formula(
theRow = Col Max( :Row, :Mod, :Device );
iRow = .;
If( Row() == theRow,
	If( .000001 - :ID[theRow] > 0,
		iRow = theRow - 1,
		.000001 - :ID[theRow] < 0,
		iRow = theRow +1,
		iRow = theRow
iRow;
// Set the Vth
dt<<New Column("Exact Vth", formula(
	a=matrix(:VG[:Row[theRow]]) || matrix(:VG[:Interpolation Row[theRow]]);
	b=matrix(log10(:ID[:Row[theRow]])) || matrix(log10(:ID[:Interpolation Row[theRow]]));
	theValue=interpolate(.0000001, a, b);
	theValue;
// Clean up
dt:Exact Vth << delete formula;
//dt<< delete columns("Row");
//dt<< delete columns("Interpolation Row");
